I would like to reproduce a 2D logo within a defined surface in Grasshopper. My goal is to distribute the logos randomly across the area while meeting the following requirements:
Random rotation for each logo.
No logo should extend beyond the boundary of the surface.
Logos must not overlap.
Ability to control a minimum spacing distance between logos.
I have tried using Woolly, but I have not been able to fully understand or control it to achieve the desired result.
Does anyone have a solution, workflow, or plugin recommendation for creating this type of pattern?
Thank you for your responses. I tried the Nesting Words V2 method, but I must admit I didn’t get a satisfactory result. The hearts are still overlapping.
I increased their size, but I can’t achieve a consistent spacing between them, and some of them extend beyond the boundary of the shape they are applied to.
I suspect that I may not be using the correct settings. If you have any recommendations or suggestions, I would really appreciate your help.
Also, I am currently using Rhino 7, not Rhino 8, so I may not have access to some of the newer features or components.
My tools still work on Rhino 7 (they must) but require some last version.
As tool works on pixel nDiv is the number of pixel and must be quite big. Let say 800 is good, but if you want after some better result augment it t0 1200 …
Number of trys must be quite big, and if not big enough you will see some space not filled.
RndPlace if false gives a better packing but the right portion could be less filled (the tool go to left to right)
For the distance between shapes, just offset shapes before putting them on my tool. If you need a distance of 1, offset with 0.5 (half).
And if you want a good filling it is important to have small pieces.
Here a script with a flattened mesh, you can use my c# (rhinocommon tool, not sure it is good in V7) or you can use squisher.
