Raised text on rounded surface
I created a surface text, grouped all the text to keep the correct spacing and have used the orient on surface command to place it on the surface of a rounded object. The beginning and end of the text are raised to different height. Is there a way to ensure that the text is raised the same distance out from the rounded object?
Thank you!
Hi Mivil - make sure Rigid is not checked in the OrientOnSrf dialog. Does that do it?
Hi Pascal,
Thank you. That is what I used. I realized that the text was placed on two different surfaces, but oriented only on one. Ungrouping the text and orienting each piece on the two surfaces worked wonderfully!
Thank you.
