Radius of the circle
Hello friends
When two sections of a box intersect
I wanted to create the radius of the circle based on the maximum distance in each node.
cover.gh (126.3 KB)
Thread title sounds deceptively simple. This GH model is not.
missing
missing2
cover-v2.gh (120.5 KB)
What Rhino version are you using?
Rhino 7
Your Kangaroo is not up to date, at least in your first file
The latest version of Rhino
rhino_en-us_7.7.21160.05001
is?
Well v2 was ok
Like this?
cover-v2.gh (110.1 KB)
Regarding the creation of the beams, I’d like to suggest an improvement:
Instead of your solution with the cluster and Pufferfish to offset the curves and then extrude twice and boolean union, you could create a center box on an oriented perp frame…
cover-v2.gh (119.5 KB)
