Radiation Result Rotation
I am not able to upload my script to this post. But I am wondering, if I have a ladybug radiation analysis setup, and want the results to rotate a grid of circles to control how much potential sunlight the ground is receiving how can I go about that? I was able to use the sun path component and its points to change the rotation with some errors, but for the radiation analysis, I’ve had no success. I would appreciate any help.
Hi Erick -
If that is because of sensitive information, you should probably make a simplified version that you can share.
Questions related to the Ladybug Tools are better asked in the https://discourse.ladybug.tools/ forum. If your question is about downstream processing of analysis information, you should internalize the Ladybug Tools output into an applicable component and delete upstream components.
