Radiance Four Phase Method
Hi, I know that the question I will ask might be a bit stretched from this forum’s main focus. However, I haven’t gotten access to the Radiance’s discourse yet, so I’m just going to ask it here.
So, I’m currently doing daylighting simulation using the Radiance Four-Phase method (4PH).
As you can see in the pictures above, my current facade is facing the wrong direction (since the facade’s preview is still white instead of black). So, the first thing that I did was flip the facade (the horizontal slats) using the “Flip” component in Grasshopper. However, it’s still wrong (maybe I used the wrong component), so I can’t do the simulation until it’s facing the correct direction.
My question is, do you have any idea to solve this? I’ve been struggling with this issue for a while and still can’t find the answer.
Thank you so much! :slight_smile:
