see screenshot.
cheers
rabbit
Hi.
If you hover the mouse cursor over the line right above the Font drop down you can grab it and drag it up.
Let me know if that helps
Well yes, I can drag that, but it doesn’t show the original “R62” and the “R<>” together. - something is wrong.
cheers
rabbit
Sorry, I don’t understand you explanation. You don’t see something like this?
No, I see either (using your example) “R<>” OR “R6.74”, depending on how I adjust the bar ie I can’t see both these things together.
Other edit dimension dialogs are fine.
Thanks
rabbit
—Sent from mobile device & email—
And you’re dragging the bar that’s above the Font drop down? Like this?
Ahhh - no, I was dragging the bar that in your example is above the “R62”.
I see now that the one I was dragging is to leave room in case you want to write a novel to replace the dimension text - it’s a hell of a big dialog on my screen, but I see now it all works as it should.
Thanks
rabbit
