I’m seeing something odd when working on 3d scanned data I’ve imported. I doubt it relates to the fact that it’s 3D scanned though.
In certain view orientations, contour lines drawn through the mesh partially disappear. It’s easier to show I suppose. Here is a view where things look proper:
And then rotating just a little bit, it looks like this:
Note the huge white band where the lines all disappear. This persists over quite a lot of view angles. It seems to mostly happen when looking at the part “from the top”. When looking “from the bottom” the lines are correct. I’m not sure what is causing this.
For reference, this is with an RTX 4070 and I’m using Direct3D
Edit: Also, this is with the latest as of today version of V9. Also, no, zooming out does not help at all.
Gijs
(Gijs de Zwart)
June 24, 2026, 5:32pm
2
@collink is that a file you could share?
https://www.rhino3d.com/upload
also pls run _SystemInfo in Rhino and post back the results
I wonder if this is related to the changes to the Cplane grid sytem in the this week’s V9 WIP? Settings are by the Display mode.
Rhino 9 SR0 2026-6-23 (Rhino 9 BETA, 9.0.26174.12303, Git hash:master @ 8cd1747b0e2a5abafffff683b0f00f4bbe7bf2a9)
License type: Commercial, build 2026-06-23
License details: Cloud Zoo
Expires on: 2026-08-07
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET 10.0.2
Hybrid graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 3-31-2026 (M-D-Y).
Integrated accelerated graphics device with 4 adapter port(s)
Secondary monitor is laptop’s integrated screen or built-in port
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 1-15-2026 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
Windows Main Display is laptop’s integrated screen or built-in port
Secondary monitor attached to adapter port #1
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26174.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26174.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26174.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26174.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26174.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26174.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
As reported in the file upload, this only seems to happen in Rendered mode and only if I hide some cut planes that I had added.
