Well any help is appriciated , it seems i am the only one with this problem .
grts
Rob
grts
Rob
What is printer brand? We have HP printer cant print “nameless” documents. So in rhino if I try to print unsaved document it wont work. If I save first it prints fine. Other applications name document “untitled” probably because of this.
i have a designjet 520 and a laser jet pro mfp3302 , both are not printing all documents are saved and with name as we have to print them in r8 now easyer.. as any time switching, btw vector output is no good at all prints the pdf size as we switched
btw i tried do a microsoft pdf print that also does not work, rhino or cute pdf works ok , the only thing i did installed lately is the duck duck go browser
Any thoughts ?
I’ve created a ticket to create a test command we can have you run. It might shed some light on what’s happening, or I should say, what’s not happening… I’ll contact you with an install link once it’s in a production build.
Ok lets try btw i remember i also had this claude try out , i removed it .. but maybe there is something going wrong with that
is there a link or so ? how to obtain this log ? or is it not ready yet ?
Hi Rob,
The command is almost ready. I will contact you with a link once it’s available for testing.
