R9 latest update can not print anymore
after latest update i can not print anymore to my designjet or laserjet
i print and then nothing happends also no print pop up or screen for printers ,have to get back to R8 to print
Rhino 9 SR0 2026-10-20 (Rhino 9 BETA, 9.0.26293.12303, Git hash:master @ 3225ee2553a4565e4ed5ef04ee64d6d334601ed4)
License type: Commercial, build 2026-10-20
License details: Cloud Zoo
Expires on: 2026-12-04
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 24GB)
.NET 10.0.13
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: AMD Radeon 780M Graphics (AMD) Memory: 8GB, Driver date: 10-18-2026 (M-D-Y). DirectX(11)
Accelerated graphics device with 5 adapter port(s)
  • Windows Main Display attached to adapter port 0
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Cooperlake MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26293.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoAI\net8.0\RhinoAI.rhp “RhinoAI” 9.0.26293.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26293.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26293.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26293.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26293.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26293.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedPositions.rhp “Named Position”
btw jpeg or pdf printing works ok , but not to windows printer
HI @robo,
Just curious, if you switch to OpenGL display mode, can you print out of the Rhino 9 Beta?
– Dale
no does not work tryed that
btw just for info , this is a new problem we never had this before with 9
Tested on :BETA (9.0.26286.06303, 10/13/26) works.
Installing and Testing now: 9.0.26293.12303…stay tuned,
Works with bluebeam virtual printer.
Hi @robo,
A few questions to help narrow this down:
  1. When you run Print, does the Print dialog appear? If so, when you click Print, does the dialog close with nothing sent to the printer?
  2. From Rhino 9, does printing to Rhino’s built-in PDF printer work?
  3. Does it happen in a new, empty model, or only in a particular file?
  4. Which Rhino 9 build were you running before this update, when printing worked?
– Dale
Hello Dale
after print , ,you see the print dialog what you want select window etc , then after you press print a small window should apear with a view of the drawing in trans green that slowly line by line dissapers then send to printer , but that screen does not apear , not in plotter or other window printer, yes the dialog close and nothing send to printer
image file does work and pdf also , but i am not sure what pdf i have used i have 3 types .
it happends to all drawings in 9
i run the build before this last one
if any ideas i can test tomorrow
grts
Rob
btw rhino pdf does print ok
and strangly , it prints now to the real printers also ? , that is weird
Ok did close rhino, opened again, tried to print and … same problem print dialog comes press print and … nothing
wil do more print test monday as i need more prints
so have to print 1 time rhino pdf , then i can print with a real printer, when opening a new file have to do pdf print again and then i can print again ,not very handy
Hi Rob,
Quick question: does printing work for you in Rhino 8 SR36? You mentioned going back to Rhino 8 to print, so I’d like to know which service release that is. SystemInfo will show it.
SR36 moved Rhino 8 to .NET 10, the same runtime Rhino 9 uses, so knowing whether it prints there helps narrow this down. The “print to Rhino PDF once, then the real printer works” clue is a useful lead too.
will check this r8 version tomorrow and if it is the last update i think so .. but will try
i have this version and it print norma;
Rhino 8 SR37 2026-10-20 (Rhino 8, 8.37.26293.10001, Git hash:master @ 24ff4ac36b4605b460e12e954c8083bc4822fdf8)
.NET 10.0.14
Primary display and OpenGL: AMD Radeon 780M Graphics (AMD) Memory: 8GB, Driver date: 10-18-2026 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 26.10.1.261008
  • Windows Main Display attached to adapter port #0
OpenGL Settings
Safe mode: Off
GPU Tessellation is: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 10-18-2026
Driver Version: 32.0.32015.7029
Z-Buffer depth: 24 bits
Total Video Memory: 20370 MB
C:\Users\robow\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\byRhinoGadget\1.6.1\byRhinoGadget.rhp “byRhinoGadget” 1.6.1.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.37.26293.10001
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.37.26293.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.37.26293.10001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.37.26293.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.37.26293.10001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.37.26293.10001
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Named Position”
Any info ? it is not very handy , Nobody printing ?
There doesn’t appear to be any print code changes between the two versions of 9 that you’ve tested. I originally suspected a .net runtime change but the version of v8 you’re using is running the same one as v9 so that’s out.
So..
Does printing a model viewport instead of a layout work?
Does switching the printer dropdown to Rhino PDF and back, without printing, fix it?
we print from our normal screen no layouts , every new drawing i have to print first with pdf before i can print normal to my designjet , i did not change anything just switching between pdf and normal with a actual pdf print , will try that , wll it was all ok printing was ok before so… what is really changed then
just tried opening rhino doing a print , after the printer dialog , nothing , then doing a pdf print and cancel the print (so no actual pdf output) printer dialog setting again the designjet on , then we can print normal, anoying it is
grts
is there a link to a previous version of r9 ? i can try that
Rob reports that previous versions of the Rhino 9 beta behave the same way as the current one. Any further ideas, @Trav?
Unfortunately I am unable to point to a specific 9 change that would cause this, and even harder, I can’t repeat it. So we might need some further debugging to see if there’s a print error that’s being quietly absorbed or a set of circumstances we can setup to be able to repeat.
We can instrument the printing code to try and track what is happening with something like a test command
