R9: Icon drawing crash
I tried making a new button icon in R9 as a hope to see if it had evolved since R8…
Good thing that curve is added now. It works OK but that’s about it.
The crash:
I wanted a free form with fill so I drew a S-shape, then two lines and another S shape. Looked for a Join command but found none. Tried to select two parts with Shift but no luck, tried drag selection and it worked, tried Ctrl-J to no luck.
Selected one curve an clicked Ctrl-J to see if I could join in another line, no luck, tried again and the entire Rhino crashed… poof… nothing.
This needs to be fixed.
For Rhino 8 I made my own SVG exporter that handles hatches as filled objects, curves and texts and when exported in the right size it looks great in R8. (But it is tedious and I have to deal with exporting and importing SVG’s)
The benefit is that I can use ANY 2D tool Rhino has to offer, I can edit hatches, use curve booleans, trims, joins, curve thickness and any other thing I could wish for.
Please consider having a floating viewport that is a “layout” of exactly the correct size so 1 unit (default line thickness) is equal to 1 pixel, so we can draw in a 64x64 grid with print preview on so we get proper WYSIWYG. I can’t imagine this being a huge thing and surely much faster to implement than to get the current tool up to speed.
With copy-paste, scale, rotate and every other tool available like rebuild, delete controlpoints etc a user would not need to learn a new way of drawing.
SVG export works great and respects draworders etc.
If I draw a circle in R9 and try to paste this into a button then I get a bitmap of the viewport… I didn’t screen capture that view, so I never expected that to happen.
Toolbars are still the worst part of Rhino 8 and the reason we still work in R7. I hope to see this fixed in R9 even though you are in Beta, so count me in if you want a workshop on how to make this a smooth operation for advanced users.
Just adding copy paste from Rhino to the button editor would be a huge step forward.
Here you can see some of our Rhino drawn vector icons. They scale great and the vector to screen bitmap anti alias behaviour is fantastic, so the core technology is in place. We just need to be able to draw this stuff easily.
R9: Curves that goes outside of the work area are drawn wonky.
Hi @Holo,
If you are on Windows, look for a recent .dmp file here:
%LOCALAPPDATA%\CrashDumps
Anything new?
– Dale
