Rhino 9 hangs when isolating objects, can take a minute or shorter or a bit longer , has nothing to do with the size of the file working with sometimes it hangs sometimes not can not pinpoint it why
or the size of the isolating objects does not matter a few lines hangs it
I’m afraid that’s not something that I’m seeing here. If you can find out what triggers it, please let us know. In the meanwhile, please run the Rhino SystemInfo command and copy-paste its output here so that we can at least make sure there are no simple suggestions to make.
i have it on both my computers a pc and a laptop it happends with different files with different size i use the isolate command ! _Isolate sometimes it happends not and sometimes and it takes a minute or so to get back when the slack is there it stays , r9 keeps hanging on isolate .btw unisolate is no problem
Integrated (slow!) graphics device with 4 adapter port(s)
Windows Main Display is laptop’s integrated screen or built-in port
Secondary monitor attached to adapter port #1
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 2x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 32.0.101.6987
Driver Date: 7-29-2025
Driver Version: 32.0.101.6987
Z-Buffer depth: 24 bits
Total Video Memory: 2097148 KB
I’ve experienced the same on my PC, I haven’t had the time to log this issue.
(Ryzen 3900X + 5070 Ti up-to-date Win11 and Rhino 9 build. Rhino 8 works fine.)
I’ve added an Alias (HH) to ! _Invert _Hide which is effectively isolating the selection, Rhino does not hang using this method.
