R9: Draworder wish: Block content inherit draworder of block
I bring up an old wish:
When printing layouts with curves, hatches and blocks we always have to check the output (PDF) to make sure that Rhino actually drew the draw order that is shown in Layout. This is a pain in the but with large drawings since it can be thousands of small things that can be different.
I tested this in R9 to see if it is improved and I see that the print preview is now much better, but it is too small.
I wish for two huge improvements:
1- that block content inherit the draw order of the block instance, so if I run BringForward for the block instance until I am happy, or use BringToFront, then this position in the draw order is the position for the content. (What we need to do now is edit the block and run BringToFront all the content, which is a lot of work since we might not want this for all instances of the block)
2- that Layouts actually show the draworder in the same manner as printpreview and the PDF output. So we finally get a WYSIWYG layout.
Hope to see this in 9.1
PRINT_block_content_inherit_draworder.3dm (6.1 MB)
@stevebaer this might be for you
