editing text is difficult , place text , go to the side panel properties , try to change letter type first select the etxt else it does not work , then change , and then the text disapears in the properties panel pointing at the text in the work screen makes it vissible again, and when editing text in properties text disapears and klick in the properties edit window makes the text dissapeir in the main window to in some cases, it is not working very fluid as in 8
just make text edit in props change text style , result , disapear in prop window , now change again text style it disapears in main window to klick on main window shows text again but not the last change in type
Hi Rob,
That was fixed last week and should be in the next release on Tuesday.
RH-97713.
There are multiple issues reported in this item. Yours is one of them.
Thanks for the feedback.
ok great , i did not find it so thanks
I’ll add it here.
I opened today my building site in Rhino 9 (created in Rhino 8), and there are more problems.
1/ some of the fonts were replace by Arial. Really annoying to go around, find all problems and must click on every text, select, remove overrides (and it is not possible to select all problematic texts and make it only once (there’s no remove overrides for all texts), you must do it one by one!)
2/ ok, then fe. video from Rh8, when editing texts in the right panel (quicker then floating window for me), I can select all words by double click or cmd+a, then righ click > make upper/lower case. Using it every day in Rh8:
Have you tried using annotation styles?
Hi Elis and Dusan -
Please add the Rhino 8 3dm file.
Yes, but as for I remember when I selected texts from 2 or more different annotations styles, it din’t work.
Sorry I am not allowed share the file.
You’d have to modify your annotation styles individually.
I’m experiencing a related/similar issue with editing text inside of the Properties panel. In Rhino 8, the arrow keys allowed me to move the cursor. In Rhino 9, the arrow keys move the selected text object itself in model space but do not adjust the position of the cursor in the text field. There is one minor exception - when first clicking into the text field, the cursor is initially at the end of the line of text (far right). When the left arrow key is pressed, the cursor moves to the beginning of the line. But, simultaneously, the text object is also nudged in model space. After that, the arrow keys do nothing when there is a blinking cursor inside of the text field in the Properties panel, besides moving the text object. System Info attached. Thanks!
sysinfo9_10_26.txt (6.8 KB)
Yes, I did it that way. However, it would be nice to be able to select all texts and have a single button to “remove all text overrides.”
But the 2nd point from my post above is more annoying. Is there a plan to make it 1:1 with Rhino 8? Currently, this functionality is missing in Rhino 9 (compared to Rh8), and there is also a bug where the ‘Select All’ shortcut (Cmd+A) doesn’t work in properties panel (enclosed videos above).
DuEI,
Just to get some clarity…
You need to be able to remove overrides of all selected annotations even if these annotations have different annotation styles.
questions:- since you can’t share the file, can you tell me which fonts are being switched back to Arial?
- does the drop down actually say “Arial” or does it say something like “some font (not installed)”?
- how many annotations are we talking about? How do you identify which ones have a problem? Do you need to look at each?
I see that cmd+a is clearly not working but in both 8 and the beta, double clicking a word only selects that word. Am I missing something?
I see the problem with the context menu on selected text has much less options in the beta than previously.
Kaleb, I can’t seem to reproduce what you are describing. Maybe I’m not understanding.
Hi Alain,
I’m not really sure how else to explain it. I can try to create a screen recording at some point. Are you testing on a Mac? Thanks for the follow up!
Hi Alain,
Here’s a screen recording of me attempting to change the location of the text cursor inside of the text field in the properties panel. You obviously can’t see me physically pressing the arrow keys but, each time the text object moves left or right in model space, I’m pressing one of the arrow keys. Unless I’m fundamentally misunderstanding the user interface methodology here, I don’t think the actual text object should move and I should be able to change the location of the cursor using the arrow keys within the text field. I’ve also attached the original 3dm file and system info.
SysInfo.txt (4.9 KB)
TextFieldArrowKeys.3dm (35.8 KB)
I can reproduce it. Thanks
