R9 Beta chamfer edges by a set angle not by amount
Is it possible to set a chamfer based on an angle rather than an amount?
I.e., if I had a solid with a recessed cut profile set into it say a letter R, and wanted to have all the internal side faces have a 25 degree angle is this possible with a single chain selection of the edges and then running a command like “ChamferEdge”?
is this currently possible or if not is i likley to be added at some point?
I changed your topic title from WIP to beta because WIP is over for a while already
Have you tried ChamferSrf or are you using ChamferEdge?
The latter does not support different distances, while the former does.
If possible share a 3dm file?
Hi Menno
Thank you for your reply. I have looked at both commands, and both require distances; I would like to put an angle in.
I don’t have a specific model, but i think it is pretty clear on the question?
A
ChamferSrf is what you are looking for. It has been improved in rhino 9 beta.
Check " **Continue across faces!" on pop up window.
See the video link:
Hi moguz
Thank you , so with this I can set the angle I want as an angle in degrees?
Regards adrian
I dont think that can be set by an angle.
Unless your chamfer angle is 45°, I’m pretty sure you need angle and distance and a way to tell Rhino which side is which…
Did you try asking Rhino AI? I did:
Asymmetric 60° chamfer on a box edge (Rhino + AI assistant)
Me: Can you chamfer this selected edge at 60 degrees?
Assistant: Found the selected edge – it runs along the top of the 100 mm box at X=100, Z=100 (Y=0 to Y=100). A 60° chamfer isn’t symmetric, so it asked two questions:
  • Which face is the 60° measured from?
  • How big should the chamfer be?
Me: 60° from the side face (shallow cut, runs further across the top). Twenty millimeters between the edges.
Assistant: Chamfered the edge, result is still one closed solid:
  • Chamfer face at 60° from the side face (X=100), i.e. 30° from the top.
  • Chamfer face width 20 mm edge to edge → 20·cos30° ≈ 17.32 mm across the top (to X≈82.68), 20·sin30° = 10 mm down the side (to Z=90).
  • Check: chamfer face is 20 × 100 mm (2000 mm²); volume removed 8,660 mm³ (½·17.32·10·100), matching exactly.
  • Done by Boolean-differencing a prism cutter through the edge and merging coplanar faces; the original object was edited in place (same ID/layer, Undo restores it).
Me: Please add dimensions and crease angles.
Assistant: Added five dimensions on the front end face (Y=0), on a new Dimensions layer, Millimeter Small style:
  • 17.32 mm across the top
  • 10 mm down the side
  • 20 mm chamfer width (placed just inside the face to stay clear of the others)
  • 150° crease where the top meets the chamfer
  • 120° crease where the chamfer meets the side face
Note: when scripting, LinearDimension.Create(AnnotationType.Aligned, …) returned wrong values (0 / 17.32) for the vertical and diagonal dims, so those were built with the LinearDimension(plane, p0, p1, dimLinePoint) constructor using a plane aligned to each measured segment instead.
Hi Martin
no i didn’t know about Rhino Ai…?
But now I do … :heart_eyes: Thank you, I see it was added to beta September 30th 2026 yay!
Looks like I need to set it up and install an ai agent or similar; I will check it out on other stuff too.
I am assuming once set up, i can then use Rhino Ai to manipulate selected solids or sketches within a bigger build and get them individually modified?
if so that would be great.
Regarding my original angle question:
I understand that more info is needed to set an angle, but ideally I would like to control the angle by an enter amount in degrees and then be prompted between which surfaces for it to perform with the option of a full contour selection, and as for length/depth then a setable amount would be good, but i would really like to see a full pocket depth option, so the chamfer would be set on the pocket side face and go completly right down to the pocket botton face where thet would join.
Basically setting a draft angle.
A
Hi Moguz
Thankyou for your input and help; the fillet surface is a good tool.
A
Hi Adrian -
I’ve added this thread to an existing feature request:
RH-746: Option for entering a distance and an angle
(I’m afraid that report contains personal information and cannot be made public).
Hi Wim
I think it would be good to set an infinite depth or a way to keep going when the selected angled side hits the next surface..
or perhaps set it as a separate feature called something like “draft angled sides”… usable on embossed or debossed features.
A
Hi @wim
Could that be implemented to chamferedge too?
