Hello Forum!
I don’t know if this is a bug. I have a python script that I used for batch export JPG from layout using capture to bitmap. The script works fine in R7, but in Rhino 8 it produces only white images (sizes and dpi remains correct).
This is a simplified script. Thanks in advance for anyone chipping in ![]()
# -*- coding: utf-8 -*-
import scriptcontext as sc
import Rhino, System, os
def export_to_jpg(layouts, folder, dpi=150):
if not layouts:
print("No layouts to export to JPG.")
return
for layout in layouts:
layout_name = layout.MainViewport.Name
filename = "{}.jpg".format(layout_name)
full_path = os.path.join(folder, filename)
print("Exporting JPG:", layout_name)
settings = Rhino.Display.ViewCaptureSettings(layout, dpi)
bitmap = Rhino.Display.ViewCapture.CaptureToBitmap(settings)
if bitmap:
bitmap.SetResolution(dpi, dpi)
bitmap.Save(full_path, System.Drawing.Imaging.ImageFormat.Jpeg)
print("✔ JPG saved:", full_path)
else:
print("✖ Failed to export JPG:", layout_name)
def main():
# Get all layouts
pages = sc.doc.Views.GetPageViews()
if not pages:
print("No layouts found.")
return
# Default folder = Downloads
folder_name = os.path.join(os.path.expanduser("~"), "Downloads")
# Run export
export_to_jpg(pages, folder_name, dpi=150)
# Try to open the folder in Explorer/Finder
try:
os.startfile(folder_name)
except:
pass
if __name__ == "__main__":
main()
System infos - assuming not that much impact on this, I still work with both R7/R8. Same plugins for both
Rhino 7 SR34 2023-9-24 (Rhino 7, 7.34.23267.11001, Git hash:master @ a37d83041828484840f2448d5b3e3770e46694f9)
License type: Commercial, build 2023-09-24
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 63Gb)
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display: Intel(R) Arc(TM) Pro Graphics (Intel) Memory: 2GB, Driver date: 2-26-2025 (M-D-Y).
- Secondary monitor is laptop's integrated screen or built-in port
- Windows Main Display attached to adapter port #1
- Secondary monitor attached to adapter port #2
Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 8-7-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 580.97
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-7-2025
Driver Version: 32.0.15.8097
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino7.Plugin.dll "Enscape.Rhino7.Plugin" 4.5.0.485
C:\Users\SongR\AppData\Local\MotifPlugins\1.7.1380\RhinoPlugin7\Motif.Plugin.Rhino7.dll "Motif.Plugin.Rhino7Base" 1.7.1380.0
C:\Users\SongR\OneDrive - Perkins and Will\Desktop\Script+Tool\blockeditnew20230807\BlockEditNew.rhp "BlockEdit" 1.0.0.0
c:\Program Files\Solemma\ClimateStudio\bin\ClimateStudioRhino7.rhp "ClimateStudioRhino7" 2.1.9190.15522
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp "Commands" 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp "RhinoScript"
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp "RPC"
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp "Rhino Bonus Tools"
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp "Legacy Rhino Render"
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp "Renderer Development Kit UI"
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp "IronPython" 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp "RhinoCycles" 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 7.34.23267.11001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp "Displacement"
Rhino 8 SR18 2025-4-10 (Rhino 8, 8.18.25100.11001, Git hash:master @ 5d157e876c23ece334d9c8666b8513ffc6d4a98d)
License type: Commercial, build 2025-04-10
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 63GB)
.NET Framework 4.8.9310.0
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Render version: 4.6
Video card is latest that allowed by IT.
Relevant topics that I could find is this, but it seems that it should have been fixed?
ViewCaptureToFile produces blank white images - Serengeti (Rhino WIP) / Mac - McNeel Forum
Best Regards,
Amy
