R8_Japanese text disappear in PDF
Hi Good day to all,
I have a problem regarding Japanese text disappearing after printing in Rhino PDF. I don’t know if I need to change some setting or not. Because I don’t have a problem like this when I am using Rhino 6.
This is the text in Rhino. I use different fonts for comparison.
This is in Rhino 8. The Japanese text disappear.
This is in Rhino 6. Note, I don’t have problem in Arial font in R6 because I use the Meiryo font.
I need the output PDF in Vector form. So that we can copy text that is on the PDF when we need to.
My work around for this at the moment is printing it in Raster. I don’t want to use this as much as possible because I cannot copy the text that is in Raster form.
I found this thread in here, we almost have the same problem.
I hope someone can help me with this problem.
Please see the attached file for the sample.
Best regards,
Jayson
R6_JAPANESE TEXT_OK.3dm (60.3 KB)
R6_JAPANESE TEXT_OK_VECTOR.pdf (358.5 KB)
R8_JAPANESE TEXT DISAPPEAR.3dm (43.2 KB)
R8_JAPANESE TEXT DISAPPEAR_VECTOR.pdf (67.8 KB)
Hi Jayson -
Thanks for reporting. I’ve added this thread to
RH-79834 Leader with Japanese text Not Printing with V8 RhinoPDF
Hi Wim
Thank you for checking the problem.
I will wait for the solution.
Hi @wim, is there an update on this problem.
Best regards
RH-79834 is fixed in Rhino 8 Service Release 11
Hi Brian
Thanks for the update.
I have updated the version of the Rhino 8 and checked.
I see that is it fixed now.
Thanks again.
