[R8 issues] Rhino 8 loads up Rhino 7 templates and autosave location
It’s not a big issue, but for some reason Rhino 8 is loading all the Rhino 7 templates and using the autosave folder of Rhino 7 by default, instead of using the ones in the folder %appdata%/Roaming/Rhino 8/
Hi Wiley -
In the different Rhino schemes that I’ve created on my system, that is not the case.
As you say, for some reason this is different on your system. Simply point those locations to the correct path.
