R8 Error Accessing the clipboard
Hi, I have this issue when moving text:
Any suggestions please?
I’m joining a video of the situation also.
I got few issues there:
1.The error accessing the clipboard message
2.Slow down in speed
3.By the end of the video around 35sec, when I move the text to desired location, after releasing the click of the gizmo the item is still sticking to it, I need an additional click to release the text object in place.
Please run SystemInfo in rhino and post the results here. I’m looking to see if there are any 3rd party plugins installed that may be causing this behavior.
Here’s the result of SystemInfo:
Rhino 8 SR8 2024-6-11 (Rhino 8, 8.8.24163.12481, Git hash:master @ ded4d86ca901dbeaf13ee84f79b3e91b22da4880)
License type: Commercial, build 2024-06-11
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.0
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3060 Laptop GPU (NVidia) Memory: 6GB, Driver date: 1-3-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.59
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-3-2024
Driver Version: 31.0.15.4659
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Lands.rhp “Lands Design”
C:\Program Files\SimLab\Plugins\SimLab VR from Rhino\SimLabVRPlugin.rhp “SimLab VR for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24163.12481
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.8.24163.12481
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24163.12481
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.8.24163.12481
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.8.24163.12481
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24163.12481
Hi -
Can you reproduce the issue when you disable those plug-in in the Plug-in Manager and restart Rhino?
I reproduced the issue when disabling those plug-ins (Please refer to the video)
Also, I realize that only selecting an object generate the action _copytoclipboard, and this is maybe why the clipboard get saturated.
Any further suggestions?
I would like to add a video where I compare Rhino 8 and Rhino 7 behavior.
In a fresh new Rhino 8 installation without extra plugins, when I select an object with a rectangle selection it triggers the command _copytoclipboard.
In Rhino 7, the rectangle selection tool works fine without triggering a _copytoclipboard.
It’s a big issue for me now, as I need to quickly produce plans for a project and the _copytoclipboard issue with Rhino 8 slows my file and generates a saturated clipboard.
Any help will be appreciated.
_systeminfo:
Rhino 8 SR8 2024-6-18 (Rhino 8, 8.8.24170.13001, Git hash:master @ c3cc7c123163b65d85b517aff795627d5b12166b)
License type: Commercial, build 2024-06-18
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [80% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 12-9-2023 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\import_DGN.rhp “MicroStation file import: import_DGN”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.8.24170.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.8.24170.13001
After consulting further posts, I finally found the problem. It was an interference caused by a dictionary installed on my PC, the selection tool was referring to the tool of the dictionary where it translates a selection. In Rhino 7 it was not an issue but for Rhino 8, I closed the app and now all works just fine, :slight_smile:
There’s a post in Chinese about that:
And a post in English:
I’m happy you found a solution. I was at a complete loss about what to try.
