R8 Edit layer name is slow at first attempt and triple click doesn't work
Hi @pascal
I see that when I open Rhino 8 and open a file and click on layers then it takes some time to activate, as if it is loading a plugin. Is that right? V7 doesn’t have this slow ness, and once it is done once in R8 then it is fast again.
I also see that if I double click the name to edit it and click in the name and then triple click to select all words then it only select the word the cursor is over, has triple click not been implemented?
Thanks
