R8 bug? On gumball relocate no object snap highlight
As the titel says, while relocating the gumball in R8, unlike R7, the object snap highlight is not activating:
Can’t find anything in the settings including advanced with “gumball” and “highlight” filters.
Quite used to it from R7, and even if i cant think of a reason why, is this by design in R8?
Atm i have to double/triple check if the relocating actually moved it where i intended.
Best regards
Afreez
make sure your gumball is set to snappy dragging in the gumball settings
Hello Kyle,Did the video load for you?
I’m pretty sure only snappy dragging let the gumball… well act snappy like that.
So yes, snappy dragging is activated.
Just the highlight is missing when relocating the GB, but works when the object itself is moved.
thanks @4f233z I see this
RH-80439 Relocate Gumball: respect snap to occluded
Well that too i guess,
But im talking about this option Object snap highlight:
R7: it does not matter if an object OR the gumball is moved, when in snappy mode the lines the snap is targeting get ‘highlighted’ by the line getting thicker once the mouspointer gets near:
R8: when moving an object, starting to draw something etc the ‘highlight’ effect is activated,
relocating the gummball dose NOT trigger it:
As an image if it’s not visible in Video (just noticed its near to invisible on a smal screen/not Fullscreen):
Hope this clears it up?
ah… totally missed that part :man_facepalming: thanks
RH-80451 Gumball relocate: no snap highlight
