Since I installed the latest Rhino 9 Beta, the bridge command in Rhino 8 has a bug. When I type in or click the Bridge command button in SubD, the SelectFilter toggle box opens…I"ve tried to stop it, but it continues. So, to do a cross check, I launched Rhino 9 Beta and typed bridge for bridging two SubD objects and the SelectionFilter Box didn’t show at al…Thought it would be beneficial to post it here to see if anyone else is experiencing this phenomena…
Installing Rhino 9 does not change Rhino 8.
Also, testing different versions of Rhino 8 (8.26, 8.33, 8.34, and 8.36) all show the same behavior - the selection filter panel opens. Perhaps you previously had this panel in the same container as the OSnaps (default config), where it’s not noticed when this panel is turned on?
I think I’ve saw the issue at this end. What I do is when the selection filter dialogue pops up I drag it into the bottom of the page and drop it in with my O snaps and then it quits doing it. So at the bottom of the screen, I have oh snaps command history, and now selection filters when I click on any of the sub pop-up tools that no longer appears on the screen. That may be a decent workaround. But I take issue with what you said about Rhino nine beta not affecting Rhino eight.
This is what I found and I would ask any other Mack user out there to see if it happens to them. When I’m using Rhino Bela for any amount of time when I launch Rhino eight all the windows containers are in its factory startup mode again all my settings are gone and I have to reset everything. It doesn’t take much time, but I wanted you to know that there is some sort of linkage between Rhino nine and Rhino eight.
