R8.5: Rebuild Command Causing Hard Crash
It crashes as soon as I use the “rebuild” command. Haven’t tried other commands.
Untitled.3dm (52.2 KB)
Update: It might be nothing to do with AutoCAD. The rebuild command just crashes Rhino. Period. I need to figure out how to revert.
Edit: Same behavior from fresh file.
Actually I’ll just use R7 Maybe… Damn…
This has been reported already several times: Rebuild crashes , Rebuild Curve on Service Release Candidate SR5 is instant crash . Logged here Rebuild crashes - #3 by nathanletwory and already fixed in the code base as well.
Thanks Nathan
Is there a build I can download right now? I’m just using R7; it’ll get the job done. Makes me appreciate the advances in R8 even more (plus lots of my aliases aren’t set up for whatever reason).
Whan will the fix be available? Next week with the next scheduled SRC? Or a “hot fix” sooner?
RH-80406 is fixed in Rhino 8 Service Release 5 Release Candidate
As someone mentioned in another thread, you can use the dash version without a crash as a work-around for now.
-rebuild
No need to with the fixed version.
