since you are at it, can we also copy paste a few more lines of code and make it work with anything that when you select, if it turns yellow, it should be in the BoxEdit input.
here… I’ll programm it for you guys. Just paste this in github.McNeel/7/final/final
-RhinoCommon:
if yellowstuff then BoxEditDammIt
/end rant
Thanks @pascal; on the plus side it looks like you guys fixed the problem with BoxEdit not tracking moved objects (R7 Boxedit bad change from R6). Appreciated!
