I moved R6 to a new machine including GH special folders.
Prior functioning scripts with Lunchbox main components now produce invalid breps.
This image looks strange with holes in breps although not in all views.
I tried removing and re-installing lunchbox with no success.
Any suggestions?
That looks more like a problem with the OpenGL clipping plane than a problem with the Lunchbox installation.
Please run the Rhino SystemInfo
command and paste the result here.
One other user has reported a similar issue not too long ago:
CC: @DavidRutten
Rhino 6 SR10 2018-11-7 (Rhino 6, 6.10.18311.20531, Git hash:master @ 0f9089a0035dcc6955732d57071445ecc29390f0)
Licence type: Commercial, build 2018-11-07
License details: Cloud Zoo. In use by: Anton Bakker ()
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: DESKTOP-038H8LS
GeForce GTX 1060 3GB/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 398.11)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-1-2018
Driver Version: 24.21.13.9811
Z-Buffer depth: 24 bits
Total Video Memory: 3 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.10.18311.20531
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.10.18311.20531
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 6.10.18311.20531
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.10.18311.20531
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.10.18311.20531
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.10.18311.20531
While not a perfect solution, it seems that if you explode the resulting Invalid Brep, then join it back together, it results in a valid/closed brep.
Looks like it may be an issue with the lunchbox plugin. Using the Brep.IsValidWithLog() method, it seems that something is not doing what it’s supposed to…
Got it, great thanks. Tested it works! Solved.
