R5 Orient3Pt bug
Hi all
Orient3Pt doesn’t work when i set up a different layer as current.It always display geometry to default one.
If you mean when you use Orient with copy = yes,
Then the copied-oriented geometry will be placed in the same layer
As the original geometry. In your case it happened that this original object was on
The default layer.
Ok thanks, could be usefull to enable copy geometry to another set current layer.
