Right/Left selection trim does not trim. (Curves on same plane, intersecting, unlocked, ungrouped, not in block) Need to manual click to trim. Video attached.
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.17
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 2GB, Driver date: 6-10-2024 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 4-6-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 528.92
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-6-2023
Driver Version: 31.0.15.2892
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
I tried to figure it out by deleting stuff and I believe it has something to do with clipping planes.
Here is the file: RHINOCLIPPINGPLANEISSUE.3dm (2.0 MB)
Thank you for your help!
Thank you for that file, Brian.
It doesn’t look anything like the file in your video, though. From opening this file, which are the steps I need to take to reproduce the trimming issue?
