Does anyone know of a quick way to navigate through various screen positions in a grasshopper script?
I want to be able to quickly wire or compare different parts of large scripts.
Using named views could be a really great tool for this but, as far as I can tell, there is no way to restore a view without clicking into the menu. This slows things down quite a bit and, and makes it so I can’t wire between the two saved viewports.
Gosh - this is the first time I’ve seen this. It even lets you create a series of jump locations and then hop from one to the next. Very nice indeed. Thanks for pointing it out.
Yeah that’s a good point, I’ll have to try and integrate telepathy more.
I had no clue about the jump component! Definitely a bit of a hidden Gem. Though I do wish you could use it without the double-click, but I can think of a few ways to wire without that.
Looking into things on my end, I also came up with this hacky way of doing it.
You can use empty wire components, select them, grab a wire, then cltr-left or ctrl-right
