Thanks. Got my f1-f5 setup now as front/left/right/back/perspective views. Only problem is my perspective view throws off the axis…
Thanks Nathan.
Thanks Eugen. Yes my space bar is my enter. I hit it about 47 millions times a day. Ill have a look at autohot key. Thanks. For now I set my f keys for views…
Hi @PeterB,
You might also like to consider the 3DConnexion Spacemouse (Pro or Enterprise models). It’s a great accessory for Rhino and much better than a mouse for navigating 3D space. But the particular advantage for you is that it has its own programmable function keys, including a set ideally suited for view selection that lie just under your thumb.
HTH
Jeremy
@jeremy5 beat me to the suggestion of using one of the devices from 3DConnexion. I originally got a two button Space Navigator. I quickly found it a must have device. I can’t imagine using Rhino without it.
I programmed one button to cycle through the four views. The other button I programmed to maximize/minimize the active viewport. I since upgraded to a Spacemouse Pro and the extra buttons allow me to jump to any viewport I want at the touch of a button. BTW, the Space mice also work in Blender making it easier to work with that program.
This sounds like something you may want to do with a programmable macro pad.
I found making one of the extra mouse buttons an Esc key was a great improvement !
it’s just under my ring finger so just have to flex that muscle
Yet have to try the 3D Connextion, heard it’s a great improvement.
I use a python script that I named FlipView.py, then F9 is just -runpythonscript “full path to script in quotes”
Here is the python script. It does one weird thing: if the view is not named with a default name, then I flipped the name of the flipped view.
FlipView.py (1.5 KB)
What do you mean it throws off the axis?
Thanks a lot for the script. I must admit I was VERY sceptical at first… rotating the view and then renaming it? That’s probably not the best way to go… well at least that’s what I thought when looking into the script.
But things changed completely when I tried out your script! Now I think It’s great! Why? Firstly because the rotation also changes the axis - which is (from my point of view) even more correct than the build in views. And secondly it turns out that rotating works great even on perspective view. Very nice!
It is a little weird but good. I also use the attached script for F5-F8 (like, -runpythonscript ‘path.py’ FrontBack for F6). This is only useful if you typically work with 4 views setup so that you have one large view and 3 small, but if that’s you, try it out. Basically, for example, if you click F6 it will swap the largest (non-floating) view with the Front or Back view (and preserves display mode.) So, basically, pressing F6 makes the Front or Back the largest, etc.
SwitchViews.py (4.0 KB)
