Quick text editor (something like V5 had)?
Having had to go back to working in V5 for a couple of days and do a lot of text editing, coming back to V8 I see some regressions that, whilst minor, aggregate into a lot of wasted time and mouse miles over the course of a working day.
Double-click to edit text: In V5, double click opens up a very simple text edit box. No frills at all, but it’s right at the cursor. Zero mouse miles. All the existing text is pre-selected and stays that way until I click somewhere in line. It’s very easy to RMB and copy. Clicking away from the text box ends the edit. All very simple and compact.
In V8: Doing the same opens up a full-fat text editor. Loads more functionality, but way more cumbersome if you just want to type, delete or copy. Existing text stays selected for the blink of an eye, then deselects itself. Slightly frustrating at times. Clicking outside the editor does not end the edit. You have to click Close. One way to avoid all of this and get something approaching the simplicity of V5 is to edit the text in a docked Properties panel, but on a multi screen set up that adds loads of mouse miles. Text doesn’t stay pre-selected there, either. Same story in the Name field of the Properties panel. If the name is long enough to bust out the end of the little window, re-selecting it (or worse still scrolling along the text to get to a part no etc that you want) is a PITA.
WISH: Could we have a sticky “Simple editor” tick box at the top of the double click text edit popup that brings behaviour similar to V5 back to the table? For all the quick ‘n’ dirty text edits I do, that would fulfil my needs at least 90% of the time. For those occasions when I need the extra nuts and bolts of a fully fledged text editor, just untick the box and the fancy stuff can reveal itself. And the dreaded Close button…
And PLEASE can you make the text in the Name field of the Properties panel stay pre-selected?!
Great criticism and excellent suggestion.
Perhaps the simplified version you suggest here could be even simpler (an ‘invisible editor’)–here’s the potential functionality:
  1. Double click text in the modeling viewport to edit.
  2. No text editor dialog appears (no pop-up animation delay, no mouse movement, instant editing).
  3. Text is fully highlighted (selected).
  4. Start typing to replace the text, or use the arrow keys to navigate around in the text. At start of edit, pressing right arrow takes you to the end of text, left arrow to the beginning. (No mouse cursor allowed–this avoids the very hard problem of cursor hit-testing in a 3D environment.)
  5. Press Ctrl+Enter (as usual) or click anywhere with the mouse to exit the text editing session.
There could be another key-command (Ctrl+Shift, etc) to bring up (or close) the full text editor at any time during the edit.
Since this has essentially no UI, I would think this could be added to V9 Beta with minimal effort (@Alain …:folded_hands: ).
