Quick scaling/resizing of complex curves
I have modelled a part and would like to change the length and width without having to redo everything. The central dish can grow in size but I would like to keep its location consistant. Is resizing of certain dimensions possible, and if so how?
I have attached three pictures below. The driving dimension is the 21.06 value, however I would like to keep the ratio the same through all dimensions. This being the secondary dimension is 93.59% that of the driving dimension.
If possible I would like to make the driving dimension 18, 19, 20, 22, 24, ect.
Thank you very much!
Hi Jonathan - If all the curves keep the same proportions relative to one another, isn’t this just a 3d scaling? If so, Scale, with a consistent base point, or BoxEdit on the object as a whole might help, since it can tell you the overall dimensions.
I think you may have use for the Scale, Scale1D, Scale2D and/or CageEdit commands.
Wow, BoxEdit - new one for me thanks :smile:
Saving me again Pascal!
The sacle2D also worked menno, but the box edit was easier since I already had the values for the x & y co-ordinates :smile:
