Hi. I’m trying to move the top face from an abject to the same level as the top face of another object using gumball but I can’t get the desired result. Seems that there is no lock or axis movement restriction when dragging the gumball and a simple way to use existing faces/vertexes as reference. For example the Sketchup has a inference locking mechanism by using the arrow keys (right=x axis, left=y, up=z and down=inference), a nice and easy to use feature to quickly and precisely moving objects (faces, vertexes) using the coordinates of other objects/faces/vertexes.
The position of the mouse don’t appear in the screenshots but on the first picture the mouse position was on the top front-right vertex position when I released the mouse, and the second picture it is the result, but obviously it is not what it is should be.
If somebody know a solution for this kind of workflow please post bellow. Thank you.
