Quick Fix: How to free yourself from "Stuck in FullscreenNoTitleMax"
If you’re suddenly stranded in and none of your pop-ups are working, autocomplete and aliases aren’t doing anything, then congrats, you’re stuck down the well!
Easy fix I just figured out:
  • Save your file.
  • Go ahead and make a change to your model (move, etc)
  • ALT-TAB like you’re going to change applications, and while you can see all your app windows, hit the Close “X” on your Rhino window.
  • When the window pops up asking if you want to save, Rhino will go back to its non-fullscreen size.
  • (Oh, and you should probably hit the “Cancel” option :wink: )
Hope this helps someone down the road…
What about running the [Reset] command after saving the 3dm file?
Remember to save the 3dm file.
Thanks, that might work, but none of my written commands seemed to be working.
Also, I found an easy workaround, so I renamed the post to help others in the future. :slight_smile:
Thanks for the quick reply tho!
