Hi there,
Doesn’t seem to be possible to create a number slider with one decimal place that has a range of less than 1.0 - for example a slider that goes from -0.3 to 0.3… Only possible with two decimal places… I know this is an edge case, but it does seem like a buglet.
Would be good to have a component that reads the active Rhino document absolute tolerance… For things like testing if a point is “close enough” within tolerance to another.
A helix component. Currently the only way to generate a helix like curve is to use an interpolated curve, which is not accurate enough at the ends… The actual Rhino Helix command generates an extra next to last control point to get a better approximation at the ends. I would like to see a helix as in Rhino, with inputs for two axis points (determines the height), radius, and number of turns/twist angle.
Thanks, --Mitch
