Questions about meshing
I have a question regarding mesh creation.
We import outlines from CAD and automatically create a mesh.
In this case, there are gaps from the original CAD lines.
Is it possible to create a mesh that perfectly matches the original CAD lines?
Uploading: picture.png…
Hello - please post an example file.
Thank you very much.
Since the modeling data to be modified will be data related to my company’s operations, so I’ll send you a simplified version of the data.
test.3dm (61.1 KB)
test.dwg (25.7 KB)
Hello- I think this setting will help - if you want a quad mesh, otherwide the normal Mesh command.
Thank you for your message.
Of course, I’ve tried its option.
Even if I choose the option of Use Surface Edges “Strict”, the mesh-line could not perfectly matched original line.
I want to know a method of automatically meshing for perfectly matched original line.
(“厳密”=“Strict”)
If your objects are like your file posted, blocky objects without curvature, then QuadRemesh will never be able to follow it precisely. Like Pascal mentioned, _Mesh is then a better solution. For example:
