Could you please help me take a look at this issue I met about interrupting points?
In general, what I want to let points on curves to move away from a central point based on how close they are to the central point, and based on how close they are, they would move 2", 4", or 6" inches away from the center.
As a result, I was able to get something like this
as you can see, there are some points no longer stay in the same branch and started moving around and creating breaking and wired lines.
if I select group of points in the list, this is what happened
as you can see, they are no longer staying in the same section.
Therefore, could you please help me take a look what I did wrong?
Thank you
