1.) Splitting object isn’t being deleted.
2.) Why does a split operation join the surfaces together instead of just splitting them?
boolean.3dm (285.1 KB)
That’s normal. The DeleteInput
option refers to deleting the original unsplit objects, not the splitter(s). There is not yet a DeleteCutters
option in BooleanSplit
If you are talking about BooleanSplit
adding the cap surface and joining it to the split parts, that is again normal - how it is designed to work. It is a volumetric operation, not a surface operation, like the other Boolean ops. If you just want to split the objects and leave them open, use Split
instead of BooleanSplit
