Question: Setting an inequality constraint / range constraint
A and B are 2 parameters in an optimization problem (in the form of number slider). I would like to set a constrain that
A*B = C where C is in the range of 100 to 200
It is easy when C is a fixed value (fixed C and only vary A or B). But is there a way to achieve if C is in a range instead of fixed value?
Thanks a lot.
