Please refer to screen shots as my question might be tricky to grasp. The screen shots show a straight acoustic horn. I have used the bend command to create the version next to it. My question is have the internal expansions remained the same or changed
Whereas originally the length of top and bottom surfaces were the same, the top is now longer than the bottom so there will presumably be variations internally. To check this out you could copy the internal surfaces and cap them so you have 15 bent, truncated pyramids and compare the volumes.
