Question on Sub d with flowalongcrv
Does anyone know what happened? When I use FlowAlongCrv, the SubD points appear as follows… And if I edit in box mode, the model becomes even weirder…pls help
Could please you share this 3dm file? Thank you.
share.3dm (204.8 KB) thank you so much
Thank you for your feedback. It looks this is a bug in Flow, and I will log it with our development engineers later. I have logged it with our development engineers.
RH-91258 Flow: Question on Sub d with flowalongcrv
Here is a temporary solution for you: you can use ExtarctControlPolygon + ToSubD to achieve your requirement, and for your reference.
Will this way lose the history?
Yes, it will lose the history.
looks like it makes a difference, wether flow is applied while box-mode or smooth mode is active
this also influences how history is updated !!
(history update in box mode is nice, while in smooth mode the nose-like shape appears)
my guess is also that the combination of crease and n-gon might be the source of some issues: (colored n-gon)
@kiga_ng did you check if flowAlongSrf has the same issue ?
extrude both the base and target Curve and
mac intel, Version 8 (8.26.25349.19002, 2025-12-15)
cheers - tom
This is flow along srf in smooth mode, you can see the distorted edge
then i edit the master in box mode , the edge becomes better from top view, but it’s going weird to the front view .
sub-d-surface.3dm (244.3 KB)hope anyone knows how to solve this problem :rofl:
Hi @kiga_ng ,
This might help…
share_bj.3dm (244.6 KB)
