Question on jittery image resolution
Hi folks,
I have a simple question: When modelling my object does look a little jittery.
Any options to improve the detail of the displayed object?
Thanks in advance, Jürgen
Hello - please see
https://wiki.mcneel.com/rhino/meshfaq
You’ll need to ‘Adjust mesh’ on the Emap dialog.
It likely is because the rendering mesh is not fine enough to show it well. In Rhino’s Document Properies, you will find a “Mesh” entry, which might be set to “Jagged and Faster”. If you set it to “Smooth and Slow” That might do it.
If not you might have to either use a finer custom mesh for that particular object in it’s [F3] properties. You can make custom meshes system-wide for all objects, but it’s not usually useful.
This is why there is an option to temporarily re-mesh it for the analyze surface: because with the chrome and zebra environment maps make it easy to see the limits of low-resolution meshes.
After you change or create an object, Rhino makes a new mesh from the NURBs geometry. That is what you see.
You can get a better look at the mesh by using a setting which can be found in each view, called “Flat Shade” which disables the nice Phong smoothing that we usually see.
Thanks, folks! That looks a lot better!
