as you can see in the image, I import some geometries through the check box component into the UI control window.
I have a small problem with this phase.
If I edit and / or move the imported geometry in Rhino, Human UI not received the modify, but I have to redo the re-import in the checkbox again.
Is there a method for recognizing the change, without having to re-import the geometry into the checkbox?
Hope the tutorial cleared it up - if not, make sure you’re not changing any values upstream of a “create” component - use a “set” component from UI output to make any updates.
