Question about "Create UV Curves"
Hi there, I am new to Rhino and I have a question regarding the “Create UV Curves” Command, when I try to create a UV curve from a “Sweep from 2 rails” surface, instead of creating a UV curve as one entity, the “Sweep from 2 rails” surface had been divided into three section and I can only select them individually. Had I done something wrong with model ? Could anyone help me to resolve this issue? Thank you.
Sweep2 created a polysurface, not a single surface. This will occur if one or both rail curves are polycurves and not simple curves.
Upload a .3dm file with your model by dragging the file to where you type your post, or use the vertical arrow icon above where you type your post.
