Query Symbolic Lines from family
Is there a way to import symbolic lines and other detail items that reside in revit families? I am trying to bake specific elements from a Revit floor plan to a rhino file.
I tried this method but could not get it to work:
For example, how can I import the swing projection curves only and not the brep? I know there are ways to filter out breps and surfaces but wondered if there is a component that separates family geometry from 2d annotations?
Thank you in advance!
Ideally in a plan view the symbolic lines should be the only thing returned.
The door family setup needs to be accounted for (solids have been turned on for 2D - Plan/RCP)
You can filter with Elefront or by culling the geometry types by text
Thank you @Japhy! The visibility setting was the key. The geometry had to be turned off for all four check boxes:
