Query Model Layer + Value Picker is freezing with a bad layer
Process:
  • blank Revit project
  • RIR 2025 WIP daily build:
  • Starting a fresh GH file
  • Placing a Query Model Layer + Value Picker
After loading a 3dm file, the routine kept freezing until I sorted out and eliminated the bad layer "Parete Divisoria grigliato 2". I could not find why the layer is a bad layer. See the attached 3dm files.
By comparison
  • EleFront Reference byLayer+Value List (expanded to Checklist) kept working even with the bad layer. It seems less picky.
See the comparison between the “Bad Layer” where the Value Picker of the Query Model Layer is frozen and the “Good Layers” which is working.
01_Full Layers List.3dm (1.3 MB)
02_Good Layers.3dm (1.3 MB)
03_Bad Layer.3dm (1.2 MB)
Hi Roberto,
Poking around in the Full Layer list file i am not able to make anything freeze. Are there other steps I should be taking?
Can we get your Rhino systeminfo? I’m on a newer version of Rhino but not aware of any changes that would affect this. Thanks
Oh, that’s surprising! Could it be a localization issue? Let me recover the data about Rhino that you need, brb.
I do nothing more than what you see in the screenshot. The file is the same, the components just those two. The Revit file is a new one.
The picker is frozen, pointer spinning.
If I delete the layer, it works normally.
Rhino 8 SR6 2024-4-10 (Rhino 8, 8.6.24101.05001, Git hash:master @ 32c244aa711e0034e75bec2e87d093c764820b96)
License type: Commerciale, build 2024-04-10
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 8.0.4
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 11-26-2019 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 2080 Super with Max-Q Design (NVidia) Memory: 8GB, Driver date: 3-12-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.86
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-12-2024
Driver Version: 31.0.15.5186
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\rb\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 4.27.1.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24101.5001
C:\Users\rb\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.6.24101.5001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24101.5001
Lets disable this Rhino for troubleshooting
If you go to File>Properties>Updates you can a newer version of Rhino by subscribing to the Service Release Candidate
Rhino 7 is not installed anymore. The datasmith installer probably has a bug and it left a plugin in a Rhino7 old folder. I disabled it and removed as you suggested.
I then installed the SRC and voilà! the grasshopper component does not freeze anymore on that specific layer. Cool, but I’m now wondering why :smiley:
P.S. I still can’t install the current daily release of RIR:
