I had inadvertently went to Twitter first instead of here.
the DOC is coming from the Active Document component, there is a gate to pick links and active or just active. I have made a work around thru a temporary revit file from which the elements can be copied and posted in place to the live model.
I am helping a team in our office and this occurred in our process that pulls elements from revit per category within a scope box. I was informed this model was provided by a consultant who performed the existing conditions survey. I have not had issue with the definition in other model files in the time we have developed and used this process.
I tested this with a linked file and everything appears functional. I’m not quite following the process
“the DOC is coming from the Active Document component, there is a gate to pick links and active or just active. I have made a work around thru a temporary revit file from which the elements can be copied and posted in place to the live model.”
A Human UI Check Box value comes into the relay above Active Document component. If the relay is 0 only active doc is pulled, if 1 both active doc and links pass through. this is from my intermediate model that doesn’t report error.
as this is only happening in this single file, we’ll keep the workflow as is for other projects, and use the builtin categories for this file. Thank you.
