Quantify volume of VA slab stair
Is there a way to calculate the volume of va slab stair? (Usually the volume stair is a sum of va slab+stair) via gh?
Thank you
Hi @fn_a you can achieve this by sorting the breps that are obtained from exploding the stair, by their volume. It should work in most of the cases, where the slab is the component that has a bigger volume.
Find the GH definition attached, which also filters stairs that have a slab component.
Stair Slab Volume.gh (8.6 KB)
