The Quality drop-down menu in Rhino Render seems to be stuck on: “Draft quality”. Is this a known problem ?
Thank you,
Andy
Thank you,
Andy
I’m not seeing that here. Which version are you running? Please run the Rhino SystemInfo
command and post the result here.
Here are the results:
Rhino 6 SR7 2018-7-18 (Rhino 6, 6.7.18199.22081, Git hash:master @ 123fa928529aea2697d4d286dda5f63a029d2a71)
Licence type: Commercial, build 2018-07-18
License details: Stand-Alone
Windows 10.0 SR0.0 or greater (Physical RAM: 64Gb)
Machine name: THINKPAD
Quadro P4000/PCIe/SSE2 (OpenGL ver:4.5.0 NVIDIA 385.69)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50 NVIDIA
Driver Date: 9-16-2017
Driver Version: 22.21.13.8569
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.7.18199.22081
C:\Program Files\Rhino 6\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.7.18199.22081
C:\Users\Andy\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\PanelingTools (6caed836-bc06-4ebc-b1fd-e10886a0dc94)\2018.3.1.650\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.7.18199.22081
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.7.18199.22081
C:\Program Files\Rhino 6\Plug-ins\Calc.rhp “Calc”
Thank you,
Andy
Hello Wim,
Please see the above for the system information.
Thank you,
Andy
Hello Wim,
The Quality drop-down menu in Rhino Render is now working. I had turned off the computer and now it is working.
Thank you,
Andy
Hello wim,
The Quality drop-down menu in Rhino Render is again stuck on “Draft quality”. Now even rebooting does not solve it. Any suggestions please as to what I might do ?
Thank you,
Andy
Hello wim,
The Quality drop-down menu in Rhino Render Is now working again. So it appears this is an intermittent problem.
Thank you,
Andy
Thanks for the heads-up! Please try to find a pattern in what is making this problem occur. If we can recreate the problem at will, we can fix it.
Hello wim,
Ok will do.
Thank you,
Andy
Hello Wim,
A work around for this is that if I go to options > Render I can change the Quality drop-down menu their and then this change gets reflected in the render tab in the program.
That is all I have noticed.
Thank you,
Andy
Hi Andy,
So, you were seeing the stuck quality in the Rendering
panel? I had only tested in the Document Properties > Render
dialog so far.
Testing now in the panel, I still cannot reproduce this setting being stuck, but I suppose you cannot either. Good to know that there is a work-around but I hope you can still keep an eye open on when it gets stuck. I take it, for example, that you have Rhino Render
set to Current Renderer
at all times?
cheers,
w
Hello Wim,
ok. Actually Sometimes I use Rhino Render Next. It seems to use both the GPU and CPU for a more balanced workload.
Thank you,
Andy
Does it look like that changing it to (or from) Rhino Render Next
is involved in the quality dropdown gettting stuck?
Hello Wim,
No I do not think so.
Thank you,
Andy
