Quadremesh gets some weird stretches
Here’s my setting,
No, I tried both strict and smart.
I used to thought “strict” means no stretch, now I know I’m totally wrong…
your initial mesh may be defect. somebody can sure tell you more if you post a portion of your file.
Thank you. It’s not a mesh, I quadremesh nurb surface directly.
stretched mesh.3dm (4.1 MB)
please extract a detail of the file, that concern you most - or is related to the initial screenshot
this is not a
kind regards -tom
in that case it is your polysurface which is a good mess. i am not fully sure what is going on also be aware that you have open edges and open surfaces. the surfaces are barely planar.
i got quadremesh to behave a bit better with these settings, strict smart no difference. the main factor seems to be increasing the target quad count. dont overdue it might deteriorate again.
stretched mesh.3dm (12.4 MB)
Like this, it stretch wildly by the opening. the weird opening is because I offsetsrf then pick random surface as a group.
Will try this setting, still curious how do you prevent it from stretching?
@DanielPiker i might have helped out here but it still looks a bit odd, to fiddle that hard with the settings does not seem right, maybe you want to have a look. i assume it could be the variety of widths between the windows? so practically you have to get the sequence right by which all the dimension can be divided… i am just wildly guessing.
Thanks for your help! I will definitely try that when time allows.
