QuadMesh not remembering settings
As per subject: for the QuadMesh command setting a size of say 2 will not be remembered at a second run of the command.
-Willem
@DavidEranen, FYI.
Reported https://mcneel.myjetbrains.com/youtrack/issue/RH-35481
Willem, keep in mind that QuadMesh development is on ice right now, so it may be a while before I work on this. Just out of curiosity - have you been using the command a lot? Is it being helpful in its current state?
