When I connect the geometry to quad remesh component, I get this result on both the top and bottom of the geometry! It seems like lines are suddenly broken near the edges
Does anyone know how can I solve this?
I used the surfaces boundary lines as guides but nothing changed!
Quad Remesh Problem 2.gh (65.6 KB)
I hope you can find me a solution… Thanks!
Thank you so much…
It solved the problem but it didn’t actually do what I want…
I need to keep the adaptive size and count, I also need to use guides so that I can adjust the mesh to follow the principal curvature lines.
Is there anyway I can do this without having lines break as in the original problem.
